HELP 7.5 Auburn?
Abort Mission and Stay Open?
  • Yes
    Votes: 2 28.6%
  • No, try to get a posi in there
    Votes: 5 71.4%
  • Total voters
    7
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
It turns out that the posi unit I was going to use is a 7.5 Auburn. One of the side gears is cracked, and they appear to be like hen's teeth. I have new spiders for the open in the car. I always hear people trashing the Auburns, but in the 90s, they were the cat's *ss with the Mustang boys. Are they that bad? I'm certainly not dropping $600 on a new one.
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
Worked great in Natasha's Camaro with 4.10s... so yeah, go with it.
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
I can't find parts. You got a good source?
Yet, another wrinkle..... I had a right 3.42 gearset, and sent it back on the premise that I was going to use the Auburn which needs a thick gear. So, I pop the diff cover to find that the open carrier needs a thin. FML
Oct 14, 2008
8,826
7,779
Melville,Saskatchewan
A ring gear spacer may be the way to go. I think Auburn's are throw away once broken
motorheadmike
8,976
27,522
bracketchev1221
1,415
1,654
The part about not being rebuildable was the only downside to the auburn that I ever heard of.
64nailhead
Goat Herder
Dec 1, 2014
5,710
12,220
Upstate NY
I believe you won't find a source for parts because they are not rebuildable. That is the downside to them and the reason to never buy a new one. Considering you can buy a Yukon that is rebuildable in the $300-400 range it makes no sense to buy a new one and really makes NO sense to buy a used one IMHO.
UNGN
3,048
3,264
Southlake, TX
I put an Auburn in my '89 5.0 back in the early 90's. Ran 3.55 gears so I had 255/60's in back to keep the highway RPM's down. Then I got a flat. In the middle of nowhere. 255/60's don't fit in front so I had match the tiny space saver with the 255/60. So much for the auburn.
If you plan on taking long trips, and have tall tires in back, have a spare tire that is the same diameter as you rear tires (and make sure it fits in front, too) or you will smoke your Auburn.
64nailhead
Goat Herder
Dec 1, 2014
5,710
12,220
Upstate NY
'89??? That's almost 3 decades ago and the last century. How old are you?
