Can they be built up to hold at all?? I really don't have the cash to spring for a GN rear end right now... I'll be around the 400/400 mark.. The car will see the track occasionally on drag radials... NOT SLICKS. What can I do to build up the rear?
megaladon6 said:the weak point is the ring and pinion. the axles are next.
I always break the axle shafts first!
I'm not rebuilding any more 7.5s.
megaladon6 said:I always break the axle shafts first!
if you're breakin' the axles, why do you need to rebuild it?
