when you switch rear ends do you need to extend the drive shaft from a gbody that had a 7.5 when you swap to an 8.5 rear? also any ruff idea what they might charge to extend or shorten it. im guessing the 7.5 drive shaft might be longer since the rear is smaller but i have no clue. i just ran across an craiglist add for a Grand national drive shaft for $100 and it came off an 8.5 rear end? so should i mod the 7.5 shaft i have in my car or just get the 1 of craigslist and if i do get the GN shaft will it bolt right in. whats the best and most cost effective way to go about this
