700r4 leak
leak
is it shifting ok?
its shifting pretty good...a lil early tho, how can i delay it?
before i had the cable installed it would rev alot higher b4 shifting...
700r4
try unlocking the cable and move the cable to the rear one notch at a time and road test until it shifts higher ,if this doesn't work you may have to get a gov spring kit,does your trans have a shift kit in it?
THAT IS FOR YOUR TV CABLE. THE CABLE GOES FROM YOUR TRANS TO THE CARB. AS U NGIVE THE CAR GAS IT SHOULD PULL THE CABLE.. THATS HOW U SET YOUR SHIFT SPEEDS.
