700r4 leak
700r4
let me try agai
n[img
G]][/img]
700r4
it looks like the throttle cable goes on top and shift cable on bottom? it should work. are you going to run nos?
700r4
my carb has a hole in the linkage so i used the second one on mine if your carb has a hole on the bottom you can use it to but if you look at my set-up you'll see that my return spring is on the same spot but behind the shift cable i mean the inside does this make sense.this is my engine.[im
g][/img]
700r4
if your asking about the one the that i'am using on my linkage it came with my carb
700r4
looks like it will work to me. good luck! jesse 🙂
