Intragration said:PowerSet said:I ideally would like to do as much of my own work on the car as possible, regardless of it being time consuming, not always the cheapest route, and an overall pain in the butt.
I completely "get" this, but the reason I would suggest not doing the transmission yourself has nothing to do with it being time-consuming, expensive, or a pain in the butt. Yes, it would be all these things, but it is also something that requires specialized knowledge, the ability to recognize small variances in internal transmission details through experience, and highly-specialized tools to some extent. If you were talking about rebuilding the suspension, or doing brakes, or replacing an intake, yeah, those things all meet your three criteria and I'd agree that it's something you might try tinkering with on your own. A transmission is a different animal.
PowerSet said:This was when I had mistaken the dipsticks, so it was the ATF that looked milky.
I mean absolutely no disrespect, but this is an indicator that maybe you should hold off on doing the transmission. You made a mistake here. It's a big mistake. Not earth-shattering in this case, and we all have to learn somehow. Sounds like there's been a transmission problem since well before you bought it, so it's not like you caused this. I'm just pointing out that the difference between the trans and oil dipsticks is pretty basic, and there are a ton of much more sublime things going on inside a transmission, and watching a video on Youtube about rebuilding a transmission isn't going to teach you these things. Again, with brakes, sure, dig in. The worst thing that's going to happen if you pay attention to the video and do things generally right is that the parts aren't going to go together right, and you'll figure it out and put them together the right way and they'll fit, or the brakes are going to squeak when you're done. A transmission? That's an awful lot of work and money in parts to pull it, tear it apart, put it back together, put it back in, and discover that it's still not working right, and you have no idea why.
To reiterate, I mean zero disrespect to you and your abilities or initiative. I think it's great, and I generally think you're going to do fine with the car. I have decades of experience working on these cars, and my advice is to take a transmission to a pro. Maybe I've been wasting my money all these years doing this, maybe I could have been doing it myself all along. But I've also had such good experience doing it this way with transmissions that my healthy respect for their complications remains. I believe that unless the case is cracked, your transmission is salvageable. But one of my concerns is that if you tear it apart and put it back together, that you may damage parts that could otherwise be reused, and end up costing yourself more money and more headaches in the long run. It's your car though, do what you feel is best. Maybe someday you'll be rebuilding my transmission.
Check out the attachment to see the differences between 700-R4 and 200-4R pans.
I definitely don't take anything as disrespectful, I know I have limited, and basically no knowledge of the cars, I did not notice the white dipstick on the side initially, as I am used to my manual japanese car, so I don't have anything for a transmission dipstick, I have the oil which is in the back, and when I checked what seemed like the appropriate dipstick and had described the fluid, I was told it sounded like moisture filled oil, which seemed appropriate to the car so I didn't look further into it. Now with my day of exposure to the car I know where the oil dipstick is, where the trans dipstick is, and the mistake wouldn't happen again, but I feel it's a pretty reasonable mistake for having worked on one car in my past and there being what seemed like no indication as to what is for what under the hood.
I suppose I have to nip all good suggestions and say that I absolutely cannot afford to take this transmission to a reputable rebuilder. If the only way for this car to be on the road is for me to pay to have the transmission rebuilt, then the car will be sold. I do not have thousands, or even hundreds in the bank. I have no opportunity to even let this car be a money pit, but what I do have is the time and drive to at least "ATTEMPT," albeit with the complete possibility for total failure, to restore the transmission, as well as everything else with the car myself.
It is not only a matter of "I want to do it myself because I'm stubborn" but also a matter of "I can't pay someone 2-400 dollars extra to do it for me"
