Ok i did a complete build to a 455 olds rocket about 4 1/2 years ago. Blueprinted and balanced and completely raw. Its got flat top pistons, bored 60 over on the crank and block. It does have the steel crank in it. the heads were redone with bigger valves, 2.05/1.90's. My biggest concern is the cam. Its got a comp 234, 244 duration with 480 lift i think. its enough to open it up but still has a pretty smooth idle. When its cold you hear it lope a little but when it warms up it runs smooth. Its also running the stock push rods and rockers.
My 1st question is What is the biggest cam i can go with with stock rockers and rods? I'd like it to have a pretty radicaL idle I would also like to leave it hydraulic as well.
2nd Im running an old school Edelbrok O4B performer intake and a jetted Holley. Its a 600 with 800 jet. I'd like to leave the carb but change the intake. Wat sugestions can i get with the Intake?
