Will a 1977 Oldsmobile 350 distributor fit in a 1972 Oldsmobile 350 need help as soon as possible thank you for your help
Yes.Will a 1977 Oldsmobile 350 distributor fit in a 1972 Oldsmobile 350 need help as soon as possible thank you for your help
Yes I wanted to order a distributor and the only one that they had was for a 77 to a 79 they told me it would probably fit but I figure I hop on the form where I can find out real information lolYes.
Olds 350 physical dimensions did not change during their production run. That means both distributors will interchange with each other.
I assume you're wanting to use the later model distributor to take advantage of the HEI over the conventional points style?
