Sounds pretty healthy ,does the carb got holes in the butterflies?thank you guys,
blades are probably cracked because i lean into it. its brutally worse at of idle,
new set up and car/build. iv run it as much as 42 degrees, back safe at 36 because it wasnt faster or slower. had same issue.
this is the only clean pass, because i floored it slowly:
