Is the rotor somehow on backwards?I can't stop thinking about it. Ok so something is wrong with the distributor but why the hell did it only run 180 out? It doesn't make any sense.
I wonder if somehow the pickup coil is ****ed up. You sure the plug wire routing was Oldsmobile counter clockwise? Just weird, I also have never seen that. The cheap Chinese HEI worked fine if you need a replacement. They have a points timing curve. I swapped the coil and module for fancy ones but they are probably fine. It looks like $60 shipped on Ebay. https://www.ebay.ca/itm/BRAND-NEW-D...d=link&campid=5335822911&toolid=20001&mkevt=1I can't stop thinking about it. Ok so something is wrong with the distributor but why the hell did it only run 180 out? It doesn't make any sense.
Is it possible that the rotor is 180 off?I can't stop thinking about it. Ok so something is wrong with the distributor but why the hell did it only run 180 out? It doesn't make any sense.
No and it makes no sense we even tried some old olds firing order I found in a Google search and it ran on that too but a bit worse. I may never know what the problem was but it seems to be better now and I'll take that and run with it.Is the rotor somehow on backwards?
I figured, but was worth a shot.No and it makes no sense we even tried some old olds firing order I found in a Google search and it ran on that too but a bit worse. I may never know what the problem was but it seems to be better now and I'll take that and run with it.
