Hi there folks!
I need your support on this one: my 78 Lemans blew its transmission and instead of the stock TH200C I swapped in a TH400 along with a new cross member made by GForce. Up here, everything works perfect and no custom work was necessary: only remove old, place new, bolt on and done. The car has standart floor shift, with a cable going to the transmission lever, which itself is linked to some equalizer levers going to the steering column. Nooooooow, here's the problem:
the shift lever of the TH400 is not at the same place as on the TH200C --> Captain Obvious strikes here, since both transmissions have different dimensions. From what I know, the TH400 was an option with the 350cui V8 in combination with the floor shift. what I need is the entire linkage between steering-colum, frame and transmission in order to get the th400 working smoothly, as it should. :-?
If someone could help me out on this, I would owe him a big favor
Thanks in advance for any kind of help 😀
