79 cutlass build thread (ALOT OF PICTURES)
looks good
How about going with a Rallye 350 theme?
It's Olds and it's yellow!! 😀
vladj said:
thanks;
ya im debating between a rallye 350 theme or this just yellow and flat black:
It's good you're gunna break up that yellow. I think it'll be cool, at least something different
i think the black would look nice. without it, in my opinion itd be too much blindingly bright yellow.
I WANT FENDER VENTS!
thanks guys im still thinking if i should go with flat black or gloss black or just go with the rallye 350 theme. what do you guys think?
well i took the dash off today:
then the car wouldnt start becuase of the god damn immobilizer. so i rewired this wire:
to:
so now it turns over which leads me to believe that there is another wire going to the distributor that i have to remove.
the reason this car has an immobilizer is because the insurance company here wont insure high theft cars unless you let them install one which is free and u also get a discount on your insurance. but still this if ****ing bull sh*t.
and the whole reason i had to remove it was because i ripped the wires from this thing occidentally when i took off the dash:
and when i put them back it still didn't work.
well today i have decided i dont want to have heat or anything like that in the car since it will only be used in the summer. so i removed all the crap related to it:
then i needed a block plate for the hole. so ive decided to cut the trunk from the parts car:
half way through i realized it had a frame welded to it in the bottom so that was a no go. so i got some free metal:
and here is how it turned out:
i know i need to drill holes and paint it but not bad eh?
vlad
