Looks like a decent start 😀 Is that a split bench? If so it uses the same seat tracks as buckets, so you won't have to go hunting or install the inside brackets for mounting buckets.
Doober said:Looks like a decent start 😀 Is that a split bench? If so it uses the same seat tracks as buckets, so you won't have to go hunting or install the inside brackets for mounting buckets.
Nice bu! I believe the newer fenders have the marker lights. Also you can splice the double head lights into the single set up, thats how my Elco was done.bapekidon4s said:dam dats cool ima sell my front clip too then and sounds good ima do the same swap i heard u could splice the old headlight setup so it could work with the new.. craigslist or ebay? oh and y 82 and up fenders? are they different or wat
bapekidon4s said:nice white malibu what year is it? hope mine comes out that good!!
Nice one there too Kevin! I see your kickdown cable is disconnected. What bracket are you using? I have the same carb and manifold and I need a different bracket or should I modify the stock one? BTW, sorry for the hijack too!O. D. Showtime said:bapekidon4s said:nice white malibu what year is it? hope mine comes out that good!!
Thanks it's an 81...here's a pic of the motor..
bigjoenvegas said:Nice one there too Kevin! I see your kickdown cable is disconnected. What bracket are you using? I have the same carb and manifold and I need a different bracket or should I modify the stock one? BTW, sorry for the hijack too!O. D. Showtime said:bapekidon4s said:nice white malibu what year is it? hope mine comes out that good!!
