8.5" B-Body rear into G-Body
Doober
1,253
20
38
Swartz Creek, MI/Tucson, AZ
Kennybill
286
401
Braceville, Ohio
Pretty big difference in the width. Is it a posi? What's the gear ratio? Being a 8.5 they might be worth something. 1964 to 67 A-bodies are narrower than the 1968-72. Southside Machine use to make a kit to use these housings. Good luck
Doober
1,253
20
38
I'm not worried about width, going to have it shortened to stock width (2"-3" overall difference). Not sure of gearing etc., but I'm not worried about that either, cross that bridge when I come to it. The 8.5" B-Body rears are pretty plentiful, so they aren't very pricey. It will also need the brackets transferred over from the G-Body rear. By the time it's done my plan is for it to basically be a G-Body 8.5", with the only difference being the upper control arm length, but I'm not sure how much difference that will make in suspension travel/geometry.
SSpev
195
301
Why not an 8.8? I've been contemplating this for my wagon. $350 kit, arms and brackets. Plus some axels.
Doober
1,253
20
38
If I got an 8.8 for free maybe... don't forget the flange on the driveshaft or custom length axles. Once it's done all I need is a pair of off the shelf axles for a G-Body, and if the last thread is accurate it's closer to a bolt-in than any other rear, not counting the shortening and bracket relocation that's typically required for most swaps.
81cutlass
4,654
13,595
Western MN
Biggest problem is the LCA mounting locations. Thats why 8.8 swaps kinda sorta work but have varied success. The instant center is messed up and is never really fixed.
Interested to see the progress.
Bar50
1,180
871
Tulsa, OK
If I say the paint is wet, would you touch it to check?
9,621
12,730
oldsmobile joe
2,067
3,053
mpls
i looked at one of these "B" body rear axle once when i had it laying around the garage, i thought the upper control arm mounts (which are cast as part of the housing) were the sticking point. i don't remember the mounts matching a g body or the axle from the 64-72 "A" body cars. i believe they are further apart.
but i will gladly be wrong. we all would love another source for rear axles. please keep us posted on your endeavor.
