So those get welded to the housing?.....is that correct?was going to use an 8.8 for my 81 malibu. went with a quick performance 9 inch kit instead. while thinking about the 8.8 i bought these to put my uppers where they should be. did not want offset stuff. i'll let these go for 25.00 plus the ride if it will help. many different ways to weld these on.
yes. i have seen several ways to weld them on the housing. my welder friends say the housing is cast steel not cast iron so they can be welded. stock arms on the 8.8 if memory serves me right are spaced too wide and too low on the factory housing. the jonny joints and offset arms did not appeal to me. southside machine did a nice job of installing these on the 8.8.So those get welded to the housing?.....is that correct?
Thanks, but I'd prefer to use the factory mustang mounts on the housing.yes. i have seen several ways to weld them on the housing. my welder friends say the housing is cast steel not cast iron so they can be welded. stock arms on the 8.8 if memory serves me right are spaced too wide and too low on the factory housing. the jonny joints and offset arms did not appeal to me. southside machine did a nice job of installing these on the 8.8.
