BUILD THREAD 81 Buick/Olds Turbo Wagon 02/15/2024 More Parts!
After a few weeks away, I'm getting back on it. Starting to work on the emergency brakes tonight. I took the emergency brake lever off of the backing plate, and it am going to modify it to accept the stock cable. I'll also fabricate a bracket to hold it to the lower control arm. Pics by to come later tonight.
Sent from my Z981 using Tapatalk
Welcome back to gearhead land Jim!!! I'm sure you are definitely glad to be home!!! This guy is following along as always!!
Thank you!
I came up with a plan for the emergency brake. What I ended up doing is modifying the lever that goes into the backing plate to accept the stock e-brake cable barrel. I cut the hook off, and used a thick piece of angle iron for the modification. This required drilling a hole for the barrel to just fit through, and a slot to let the cable slip into. I slotted the whole piece so I can slip it over the cut lever, and weld them together.
After welding I trimmed everything up and have a nice lever.
To hold the cable, I again used some angle, and made a few holes. A file and some paint has it looking good. I drilled two 1/4-20 holes in the control arm to hold it, and some stainless ARP bolts with loctite keep it in place.
And finally, I used a short piece of vacuum hose to keep the spring from chafing the paint on the rear, and put it all together. It works like a charm.
Now to do the other side.
been awhile since I've been through the entire thread, but do you have the calipers mounted forward or behind the axle? this was a clever idea, hope you don't mind me copying it when I get back on the Regal...
Reactions: Rktpwrd and Clutch
Thank you. The calibers are mounted behind the axle. They are rotated up a hair, giving me clearance for the shocks.
I completed the driver's side, they work perfectly.
Yesterday I installed the new highway stars ac lines, accumulator, and Delco ac compressor. Nothing really fit so I had to bend and tweak everything. Then I pulled a vacuum for 3 hours and charged it up with r134.
Don't mind the dirty engine bay.
I also installed the new carpet.
Dirty?....I wish mine was that dirty lol
Reactions: Texas82GP
My stupid email service is bouncing back all the good build threads!!!.
Just caught up on this AWESOME build!!!
A tow hitch on that beauty?!!?!?!?!?!?!?!?!?!?!?!?
That better be there to tow my car to your shop!!!!!!
Thank you gentlemen, I appreciate the compliments.
Small update, I'm asked to paint a couple of interior parts. The kick panels, the b-pillar lower covers, and rear side seat lower covers. I had to redo my sill plate since to Plasti Dip didn't work out.
I also fit the new carpet.
