what im goin to do is just dye the dash a brown to match my engine brackets and put a dash cover like mel i dont wanna fill the cracks and do all that extra work cuz once its brown and the cover is on you wont be able to tell and ill have the dash cover made it will come down more over the front of the dash.. ill make it as clean as i canBumpin1ohmSS said:Lookin damn good bruh!! You movin quickly on thangs. I gotta get out there and see this clean assembly line work you doin before its all buttoned back up. My og dash project was cracked in the same spots. I was gonna glass it, but then went with a dash cover. Would have turned out sweet if I would have used the correct adhesive. Used 3m VHB (Very high bond) tape. sh*t stuck like crazy glue as soon as the cap met the dash. You need something with a "work time" to get the dash seated into place. or you can fill the cracks. You'd have to use a "textured" finish paint tho or the filled areas will be seen....
Warren
thanks.. i was happycarmangary said:Wow what a find.
o and to top it off warren me and mel kno this guy wit a el camino he had the black parts of his dash bezel radio bezel and gauge pod bezel redone with a urethane paint it cam out clean and the chevrolet on the dash bezel was shaved clean i want mine done like that but i want kuruption added were the chevrolet is in a similar fontBumpin1ohmSS said:Lookin damn good bruh!! You movin quickly on thangs. I gotta get out there and see this clean assembly line work you doin before its all buttoned back up. My og dash project was cracked in the same spots. I was gonna glass it, but then went with a dash cover. Would have turned out sweet if I would have used the correct adhesive. Used 3m VHB (Very high bond) tape. sh*t stuck like crazy glue as soon as the cap met the dash. You need something with a "work time" to get the dash seated into place. or you can fill the cracks. You'd have to use a "textured" finish paint tho or the filled areas will be seen....
Warren
thanks its a work in progress working on my dash right nowbigjoenvegas said:Great find!!!!!
