83 el Camino ls swap
Try converting. 020 to mm, then see what you come up with. I doubt it's going .20 over.
Yea it’s going 0.020 over I found pistons im going with speed pro hypereutectic 50mm they have a 3.80inch bore 96.5mm bore but that is depending on their compression ratio
Ls7 lifters and tray are here, Melling high volume oil pump, arp head bolts all came today, waiting on pistons, main and rod bearings, pistons, cam and gasket kit hopefully engine will be together mid next week and we can drop it in and plug everything back in and have her fired up
New engine is in and she’s almost ready to home just add the exhaust
Can’t catch a break first the original motor lets go we get the new one in and running and the driveshaft is 3 inches too short and sticks out the transmission
The gentleman I had do it was older he’s an amazing driveshaft and transmission builder I just think it was an honest mistake we measured it 10x at least the yolk is only in the rear of the trans prob 1inch so I need another $300 for a new driveshaft
Still waiting to scrounge up the funds for a driveshaft but it needs that and the exhaust work then work on paint and body
Got 700 miles on the car now got a little oil leak we think it’s coming from the rear main but it’s not super bad, trans shifts hard motor is strong next step is fixing some of these holes and paint had a cousin pass away in May and I was determined to get it running and driving in his memory and it’s a bad cat so far
Ok ok it’s been a very long time lol I got 3500 miles on the car I just scored a 6.0 0.20 over super cheap it’s got a lsx intake, 1250cc injectors, gen 4 rods, stock cast pistons, arp hardware everywhere even the intake bolts, hooker blackheart turbo manifolds and we are putting a gt45 turbo on it going with the Holley terminator x Max ecu and a 9 inch from qp I forgot to mention it’s also got a btr stage 2 turbo cam with valve train upgrade and a bronze trunion upgrade
