Mine were some cheap adapters with Moroso solid mounts. I would suggest the Metaltek mounts if you are doing more custom things than what the PnP Holley kits provide.
He's asking which transmission dipstick to use.I used Allstar Performance. They were cheap. The Dirty Dingo ones work well also.
Summit racing 4L80e or Allstar Performance th400/4L80e.Oh, the one from Summit that Northernregal and I had worked okay.
Yes, with some minor hackery. I know you own a welder, or slept at a Holiday Inn Express, because I seen your build thread. I had to put a cut in it and rotate minorly and re-weld. It took almost 20 minutes and a coat of high quality Krylon to hide my hackery.Does a stock truck tube not fit? I was under the impression it does.
You have to see that same tube now re-worked around a flexplate scattershield - the hackery is somewhat more obvious.
