The one I have now is computerd..
you said you wanted to eliminate the smog stuff. You can not use another carburator that does not work with a computer. You need to change the distributor as well.
DUI makes a good non-CCC HEI that will work well for your SBO.you said you wanted to eliminate the smog stuff. You can not use another carburator that does not work with a computer. You need to change the distributor as well.
That looks like a nice rebuilt Qjet but are the primaries tuned for a stock SBO 307?https://www.summitracing.com/parts/jet-32002
This is what I went too. Bolts right up and didn't have to adjust anything. You do have to change the distributor and run a wire for electric choke.
Yes its for stock. I put it in my 84 Hurst Olds that has the original 307 in it.That looks like a nice rebuilt Qjet but are the primaries tuned for a stock SBO 307?
I have the quadrajet from a 79 Olds 403, these are used to swap out the CCC ones since they have the correct throttle linkage to hook up the TV cable, $125 if interested
