Yeah, you need to get rid of that pink hose. 😉
If my Olds motor wants to identify as a Prius motor....well its 2019 and its Therapist says thats perfectly fine. Ze's lawyer is already filing the paperwork for the lawsuits against all involved who have misidentified itYeah, you need to get rid of that pink hose. 😉
for now i am using the old one off the 308, only because I'm broke. LOLLooking good, get that bad boy running. I have also used that red hose on the thermostat housing. Less obvious on a gold engine. What intake are you using?
Did you rotate 90* at a time while priming?I got everything put together and put some purple power break in oil in today and primed the pump with the drill until i saw the oil coming out of the push rod/rockers.
I think I'd be having a talk with the place I got it from- that's bullshit.The driver side motor mount holes on the block have helicoils and one was damaged on install from the rebuilder. I couldnt tap it or anything. I will need to drill it out and put a new one
