Hey, y'all. I spent probably a couple hours taking my steering wheel off and the column apart a little to remove and replace my turn signal switch (actual electronics, not lever). I went to put the wheel and such back in reverse order and found that my wheel moved around... a lot. Definitely more than enough to cause issues while driving. Everything is back where it should be, not sure why wheel is being so odd. Column is fine and stable as it should be, it's only the wheel. Car is a 1984 Grand Prix LE with the tilt column. Please help, thank you.
