BUILD THREAD 84 Hurst Olds - TechG8
Just curious, what key on positive did you use?
-Gonz
Have a question, do you guys still want me to post that other information that goes with what I already posted?
Consider converting to a heated O2 sensor. Just add key on power and a good ground. Then the sensor wire just can be attached to the factory connector.
I credit 307 403 with the suggestion that got me moving in the right direction.
The hardest part was relearning the CCC system and triple checking it's functions. Trying to diagnose the exact cause.
The Fbody site was just corroboration. And part numbers.
It seems so obvious in hindsight. The knowledge was worth the time though. This was fun
Thanks Ken! You went above and beyond with my Qjet. A little washer fixed it. Sometimes a simple solution fixes a problem. I figured a header won't hold heat like a cast iron manifold, so a heated O2 would do the trick.
Thanks for the Distributor wrench trick guys. I used a 1" open end wrench on the distributor "square", and with a little persuasion via hammer, it finally broke free and rotated.
With the test terminal grounded at the ALDL, I set base timing at about 20-24 degrees. It was flopping around a little bit I assume due to a sloppy timing chain.
That done, I readjusted the carb and tuned the mixture control solenoid dwell. It starts easier, idles perfectly and responds to throttle inputs very well.
Had the Ttops off today....perfect weather. Hot sun and cool air. Well till the afternoon rain started anyways.
Only a few things left to do now.
Oil sending unit failed - R&R
gage pod foil circuit issues - cleanup, reinstall
Headlight / turn signal circuit funky somehow. Everything works but not quite right.
Tighten and Loctite the tilt steering wheel mechanism.
Wet sand and buff the repainted top. get rid of fish eyes, drips etc.
Nitrous?
