Looking to add bigger "breathing" holes in the blockš
Ā
Oil sending unit GM p/n if you need it: 459417 superseded to 14036243 superseded to 19244933.
Headlamp switch GM p/n: 1972717. The new ones since 1987 has the round bulb on the switch pad. The original one with the ovoid looking side view of a headlight shares the same part number. If yours is bad, the new one fits and works, but I'd try to find a good used original style if possible. JMO.
Turn signal switch if you have issues (with tilt and intermittent wipers CD4): 1997983 (ACDelco #D6222)
High beam switch down on the column: 7838234
Pulse wiper switch w/CD4: 7843683 (This is the EXPENSIVE ONE)
1972718 superseded to 10469420Do you have a number for the instrument panel lighting dimmer rheostat?
