84 T-Type Questions, and Rebuild...
A wire over by the battery that I forgot to plug in caused no spark. A none working injector. Timing out. And wires that weren't installed correctly even though the coil is labeled.
Well thanks to mister Bweavy the car is running great, no more vacuum leaks, no more lifter tick, however my transmission is effed... lol.. YAY! guess i need to rebuild that too. In case anyone has any fast fixes, its shifting to early, and then its not down shifting like it should... it about wants to cut off when coming to a stop..
Thanks,
The Beabs.
Thanks,
The Beabs.
I assuming it still has the 2004r if so unplug the wire from side of trans if the lockup selinoid is going bad it will cause the car to want to stall while stopping. Drive it and see what happens. It also sounds like the detent cable is missed adjusted causeing shift issues.
x2
another common issue is a gummy governor assm. can cause shift issues
where do i find the governor assm. located at? i dont know how tio adjust the cable, it ran fine 2 weeks ago. then today acting up after about 10 mins of driving.
i will try unpluging the wires and seeing what happens. but im having issuses with the downpipe at the moment so i will try after that.
