hi. i have an 85 olds 442. put on the flowtech short headers at least six weeks ago, ever since then the car seems like it is idling rougher at stops, dying sometimes. and just running roughly in general. often the car will bogg down when i hit the gas after a stop.
i think i have readjusted the idle screws since then, but im not sure.
sometimes in this northern IL winter, the car may die often for short travels of 5 minutes, i wasn't letting the engine warm up all the way, so it will die sometimes coming up to a stop if i dont hold the gas to about 2k+ RPM or shift it to neutral.
a week ago or so the car wouldnt start from normal "single pedal tap to engine start" method, and i had to hold the pedal in all the way until it sloooowly crept up to life, and then it immediately smelled like gas big time .. ive had to do this a few times... more recently though i had it die in a parking lot, after making a brief trip from my home, less than 5 mins and didnt really let the engine warm up.. it died two times in a row trying to leave a parking lot. after waiting a few minutes i had a b*tch of a time getting it going. i tried all my pedal manipulating changes to put different amounts of gas in it. then i open the hood to see if the choke is working... yes the choke plate is working and opens and closes at the proper times, but there was no gas in the carb at all .. .even after pumping the pedal a ton. this has now happened a couple times to me and ive had to get it running on starting fluid.... yesterday i let it warm up for 5 minutes, took a 5-10 minute drive to post office, left the car running the whole time and then came home.. so it was a total of 50 minutes running at least, then 10 minutes later i need to leave and as i am accelerating out of my street it dies on me completely and will not come back to life.. no gas in the carb again...very full tank o gas. i get it started with starter fluid, let it sit for a few minutes, the choke plate opens up signaling that it is warm, the pedal linkage and throttle assembly is working and connected well. i rev it up a little bit manually, and as it is revving down, the engine just dies. started it for work a few hours later and it was fine ... if i just baby it by slowly accelerating and decelerating it seems fine.
i bought a new fuel pump and will install that tonight. other thoughts appreciated
