85ss turn signal not working
85ss/85gn
261
228
beaver dam,wi
Have a 85 SS. Been sitting for years and got it running again. Replaced the bulbs. I can't get the driver side turn signals to work. The front side marker flashes when the four ways are on. Everything worked when parked. Any ideas on the issue? Fuses are all good. Only thing I changed was the steering column with a rebuild one.
CopperNick
2,811
2,459
Canada
Check the flasher module. If it has sat for a bit, it can go stupid. And make sure the bulbs you used are correct for where they were installed. Some of those sockets take a dual filament build while others only require a single filament. A double filament bulb in a single pin socket will drive you nuts because both contacts on the bulb can be getting power from the one socket contact at the same time.
85ss/85gn
261
228
beaver dam,wi
This little guy?
