86 Regal 350 swap- questions
All small block chevs are the same. The 350 and 305 are 100% identical in every way externally. The only thing different are the internals. If it has a 305, the 350 is a direct swap. I am also currently in the process of swapping my factory hunk of garbage 305 for a 350 that I built.
Hi, I am currently doing a Manaul 4 Speed Saginaw Swap Into My Elky. It is pretty Easy! I Bought This Set Up From ThePartsPlace, Inc! And Could Not be Happier With Installation! http://thepartsplaceinc.com/ocatalog/pa ... rList=1986
All You Need To do Is Take The Bracket Out That Holds The Brake Pedal And Swap Brake And Clutch Pedals In, And Get a Longer Bolt And Then Install It Back In The Car, I Was Amazed It Only Took Me About An Hour To Swap Pedals With The Full Bench Seat Still In The Car! The Kit Is For A Mechanical Linkage As I Like The Old School Feel Of A Clutch, If You Want To Do A Hydraulic Clutch Set Up, Head Over To Maliburacing.com and Hit Up T5MonteCarlo, He Is Full Of Information About Installing Hydraulic Set Ups In G Bodies. Good Luck With Your Build. Here Is A Pic Of The Pedals In My El Camino:
