87 Cutlass window sweeps
gharris79
Sep 21, 2011
87
38
Miramichi NB Canada
I'm looking to buy a set of outer window sweeps for my Cutlass. I can't seem to find any. I see different post about people needing wide ones. How do I know what I need before ordering? Any links to web site would be great.
Thanks
dacutty
11
Near Detroit MI
I just looked and Gbodyparts.com has them:
http://www.gbodyparts.com/product_info. ... ts_id=1670
I'm pretty sure that Mikes Montes has them too but I'm not sure if they are 100% correct.
A year or so ago when I got my inner sweeps I picked them up from an outfit that sold them on Ebay. I'm pretty sure this is the outfit I got them from:
http://www.ebay.com/itm/1981-1988-Oldsm ... 04&vxp=mtr
I did not do my outer sweeps because it looks like you have to remove the window glass to do it. There are several Philips screws holding them in place. There is one that I don't think you can remove without removing the glass. Uhhhg. If anyone knows a way around this let me know.
20,397
to replace the door sweeps you remove the door panel and drop the window down to get to the philips screws. If you take the window out to replace the sweep you have a good chance damaging the sweep trying to get the window back in..
you can also get them dooe sweep and other parts here..
https://www.nosreproductions.com/index.php
86 Grand prix
305
11
Chocowinity NC
Remove the door panel and take the lower glass stop out and the window will come down just low enough. I think It was held on with one bolt.
88hurstolds
1,748
658
Thanks
Well do you have a wide chrome molding on the top of the door?
The sweeps for those are different than the thin bead one.
Dixiemontecarlo.com has all those aftermarket, not sure on the fitment...
I have a set of thin bead WS from GM and the correct ones for the wide moldings, if interested send a PM.
marz442
249
Cicero Il
I need a set also for my 87 olds cutlass. Can someone please post a pic of the difference, and who has the best fit close to omen? Please help.
88hurstolds
1,748
658
The difference is that one comes with the thin chrome bead and the other doesn't because it's stapled to the wide upper door molding.
Aftermarket weather-stripping generally doesn't fit right as I've seen and experienced with hardtop roof molding but sweeps are a little more forgiving. IIRC the thin bead design is different on aftermarkets.
I've seen this topic covered before on a few sites so a Google search will answer your questions if you require photos for comparison.
8,827
7,783
I bought mine from Rock Auto. My car has the wide chrome and the replacements have the thin chrome strip. Just remove the old sweeps and tuck the new ones under it. You remove the door panel as said and a stubby Phillips and bit taped to a 1/4" wrench. My car no longer has awful wind noise and no more clunking windows.
dacutty
11
Near Detroit MI
Holy cow, that is a great idea, here I was thinking I had to take the glass out. I should be able to knock this out now. I remember adjusting the stop on my other car but I never thought to remove it to lower the window itself. My 87 442 needs the outer sweeps replaced badly. It's the next project on the punch list.
marz442
249
Cicero Il
88hurstolds said:
Thanks
Pm me a price for thin GM sweeps
