- Jan 2, 2006
- 7,012
- 113
The originals were "hot stamped" and the chroming was very fragile and easy to wear off. It appears these are a decal of sorts, like shiny chrome mylar tape. Which might be better as if it wears you can replace it.
I did ask and they can also chrome the shifter slot and gear select. I’m going to send a set to be refinished soon.The originals were "hot stamped" and the chroming was very fragile and easy to wear off. It appears these are a decal of sorts, like shiny chrome mylar tape. Which might be better as if it wears you can replace it.
It got me thinking, with my plotter cutter, if I can find some chrome mylar adhesive sheets and cut out decals to fit...hmmm
Yes, that is correct.Those look amazing! Is the pinstriping the shiny foil like the originals?
