Dave V said:You are doing a killer job
Thanks Dave!!! The fellas shot thru and helped Saint pull the 2004r out the El. Cool *ss day!!!! 😀 We had 3 different car clubs chillin and puttin in work to get the trans out and help get Tuck back on the road. I chilled and let Saint do the work as he was getting a free ($1300 rebuilt) trans, fresh wheel wells and a nice steering gear box. Good times most def! When Saints th350 gave up the ghost, I knew I had to step in. I have a built 700r (brand new) and TC sitting here so I shot the word out to him. Finally got around to drilling the last 2 holes out on the backing plate. The homie Allen (MR HoodWrench) shot thru and we worked on it and the 7.5 (my old rear from my SS project) for his malibu. Knocked both out right quick. The Grand National rear is now painted and Ive stripped the rear girdle of its bolts and prepped it for the powdercoater...
Fabbed some brackets up for the shock relocate... 1 set for the 7.5 and the other for the 8.5
Pic of em mounted on the 7.5..Same thing for the 8
Cut the angle iron for the e-brake brackets im fabbing up...Pretty sure theres a better way to get the ebrake to function on the LS1 swap, but imma try this out. If anything, I got a chance to learn how to use a few new tools...
[youtube]-zO8fk9iwtE[/youtube]
Made a template..
Coming together..
Angle iron was a lil thick for the stock ebrake clips tangs to push thru. I tried to remedy this by milling out a little under a half the thickness of the angle iron.. Cool cuz I got a chance to use the tools to do it...
[youtube]P8MjhKjWh9E[/youtube]
Finished.. A good look and worked like a charm on test fit....
Mounted....I used fine thread grade 8 bolts, washer, lock washer and nyloc nuts. A little medium strength thread lock to make sure things stay seated...Im also rubed a lil red lube on the flange just incase moisture somehow gets in there.
With the rear end done, 2004r out, fatmat laid, shifter done ect...Im pretty much just letting the elco sit til I get the moonroof installed and then paint. Imma have my trans shop do the 700r4 install as they will need to do all the electrical work needed for the tc to do its thing (brake light kit or whatever). I still need new glass, weather stripping ect but that will come later. Goal is to have her ready for the Vegas Elco Run in October :wink:
Lil vid of the 8.5
[youtube]Ks_ZhD-q070[/youtube]
Thanks for looking..
Elco Warren 8)
80z!!! We Comin!
