87 El Camino Daily Driver/Weekend Cruiser
DAMNIT!!!! added a malibu,really??!! :shock: man i give up with trying to "keep up with the WARRENS"!!! LOL,you on it homie.wanted to share a technique with you on them braces,for future or other simular pieces you may need done on your "FLEET" :wink: start off with a good ground surface,on contact and piece you are welding,then drill some holes in the braces(metal),around six would work for the braces(3 on each side tab,and space them about an inch and a half apart)then dial in your settings,best way is to as you know PRACTICE on a scrap piece,then when youve got the welder dialed in proceed to fill the holes you drilled in by placing stick over hole at a slight 45 degree angle and hold trigger(weld)for 3 seconds(mississippippi method :wink: ) and continue on to the remaining holes in a "cross pattern"(like tightening them irocs)this way the heat distribution is somewhat controled.this which was taught to me by my cousin(master welder,who does all my welding on my projects,and who teaches welding shop at the local community college)has given me GREAT RESULTS,and is much easier and will provide a stronger weld at this point in your "learning of the weld"opposed to the "popcorn/splatter"your currently getting.although like you mentioned,this is a place in the cruck that will not be exposed and covered,so its all hood 8) also your weld may seem pretty "contacted",but if you were to say "smooth-out" clean up the weld with a grinder i dont think they would hold? welding is SO much FUN once you get a basic know-how,do's&dont's and BELIEVE me you wont want to put down the stick!!!! :mrgreen: once i get my t-top double s to our friend gerald,(and after i finnish up the el,paint and fine tunning :wink: ) im gonna be welding a t-roof to a hardtopped double S i just purchased!!! cant wait.nehoo Continue to keep it 100 and ill be posted for the next "this is how to build a el"installment from you :!:
Awwwwww damn!!! Thanks for the tips bruh!!! "The Warren's" :rofl: I was just gonna "clean up" all the splatter around the welds, and go over a few areas. It's a wire feed flux welder and yes it's pretty fun! I gotta pick one up just to play around with and then graduate to something better later. I figured since the welds are gonna be covered, I wouldn't worry so much about em being super "clean" , but to have a nice "bite" and hold for the long run. I will use the drill on the Bu's brackets. Thanks for that tip!! Now I remember that Tha Prez Elco Mel said to do em that way... I still gotta do the shifter brackets and console bracket, and will use that method to ensure a nice bite. I may drill a hole in the center of each tab and use a nut/bolt for extra hold(maybe?). All this is new for me so I'm open to suggestions. 😀 Thanks again Fam!!! Just woke up and trying to get motivated to get it crackin...That nightshift is a project killer. :x Headed to "Tha Shop" now :wink:
Warren "G Body" 8)
80z :twisted:
Sup big bro?
Just got back from elko warren crib and :shock: :shock: killing da game, goodies all over the place!! I swear i didnt want to leave... Had a good time chillin with u bro, tha roc shop is every mans dream!! Keep it pusing big bro!!
nice looking machine, how tall are the tires from the ground up? Do they rub on the inner fenders? Do you know the offset to the wheels?
Thanks bruh! The fronts rubbed when trying to make a sharp turn. The rear setup has a 1" spacer so the wheel doesnt hit the frame. Rears rub on the fender lip when I turn into a driveway. Rolling the lip will take care of that(Im not going with the chrome trim this time around). Not sure on how tall but will measure and send you a pm. I have the spare left-Melman109 has the wheels now..Thanks for checkin the old girl out...
Lil bit more work done yesterday. Hit the Grand National rear with the wire wheel, acetone cleaned it and sprayed with some Eastwood Extreme Chassis black Primer. I have to let this cure for a few days and then Spray the Extreme Chassis black Paint. The Paint has 3 times the black pigment in it making it really really deep and rich looking. I shoulda went with semi, but got gloss. Hopefully it will look clean...This is where I had left off on the rear. Aircraft stripped the old POR-15, and then hit it with a wire brush..
Sat for a while so I wire wheeled it again and cleaned it up. Then The Primer...I still need to cut the flanges for the LS1 backing plates. Primered it so the lil surface rust wouldnt come back
TA cover/Girdle wont be staying. Swaping for the LPW rear girdle and cover brace bars. I have this for my 7.5 rear. Sweet lil setup
Mocked up the lines and braided line. I need to sand blast the lines again. I didnt coat em. Lil surface rust. I could wire wheel em..
Mocked up the Edelbrock Anti hop bars and C Fiber dipped C3 Fab upper bars. Its a clean look...
Also Finished up the bracket welding "attempt" :mrgreen: Came out ok. They are in there trust me. LOL! Primered and coated with some rustolium. I left my chassis saver in AZ.. After it dried, I laid the Fatmat and mocked up my SS seat. Just need to drop in the center console and measure it all for the tack weld...
I still need to do the foot area, weld in the weld in the center consoles rear piece, and the shifter brackets. Not as hard as I thought it would be. I also did some cleanup on my posi 7.5 rear and smoothed the wheel wells for my 78 Malibu. Got a lil done this weekend. Just waiting for the other rear girdle and bracing to come so I can weld in the mount tabs and then paint the 8.5 up...
Few more pics of the 8.5 rear cleanup here...
http://www.flickr.com/photos/bumpin1ohm/sets/72157629396728369/
Pics of the 7.5 cleanup for the Bu. Been a busy weekend... :wink:
http://www.flickr.com/photos/bumpin1ohm/sets/72157631796742073/
Thanks for checkin back..
Warren "G Body"
80z :twisted:
hey bro to save you some time use the good ol STEEL WOOL pad to clean them brake lines.. it will also give u a LOW KEY polished look. lol u remember how my brake lines came on the the elco back n phx
:shock: :shock: :shock: nice nice nice!!!! Wow i live that rear end cover, i need to get one for the malibu.. Text me with the info for that :wink:
You need a girdle for a 7.5" rear, I see new from t/a 150$ shipped a lot on ebay.
