melman109 said:
looks nice and clean under there, those are the c3fab upper and lower trailing arms right??
Yessir!!They are coming out as well. Gonna run all Spohn suspension in the SS.
LSCustoms said:
those rear arms are the sh*t!!!
Thanks bro!!! I really wish I had of snatched up the adjustable set tho. Next time around I will on the SS :wink:
Dave V said:
Great looking rear u got there
just playing bro......it look great love those rear arms.......I think the gn rear is perfect for the el......
Checking out what im working with eh?!! HAHA! Thanks bro! Yep. Should work our really nice in the old girl...
80ELCAMINOFLAKE said:
Tell me about those arms..last time inwas there it was like heaven seeing them under the monte!! Keep up good work brah
Thanks fam!!!!
hoodfellas1987 said:
Looking CLEAN looking clean Elco, but what are you going to use to connect that e-brake i have that same setup with my rear end i picked up which came with disc brakes already not corvette brakes but i haven't found where to find the setup for that e-brake
Thanks for checkin it out bruh. Ive done a lil research on it and found a sweet lil idea. Its basically a piece of angle iron notched and holes drilled to mount behind the backing plate.. here's a few pics..(not mine)
The notch is to clear the axle tube. I'll cut the edns off the stock l/r ebrake cable, and cut the end section off the donar cars cables. Splice/weld em together and that should work fine. I'm swapping the backing plates around-"L" on the passengers side and "R" on the drivers side. This will move the caliper behind the wheel and position the e brake levers on the backing plates to pull forward. The SS maro's cables run over and behind the axle. Our G's have the e cable running in front of the axle tube. Here's a few pics. This guy did a lil something different, but you can get an idea of whats going on...
Of course theres other ways to do it. This looks pretty simple and cleam. I'll make a template, and mark/cut the angle iron to size. Then mount it and see what happens..
Worked on my lca's Foose gave me....
[youtube]0snVsjaL2r0[/youtube]
[youtube]RRXCcH4kjG0[/youtube]
[youtube]SPMDegBrDAU[/youtube]
Elco Warren
