87 ss tail lights not working
if no one has played with the wiring near the fuse box then I'd check the connection of the harness near the tail lites to make sure it's a good connection. If someone has spliced into the wire for a trailer harness that will most likely be the problem. The aluminium wire will break if slicked into, it's terrible wire
ummmm it didnt look to loose from the fuse box, but i should double check, when it enters that tube it looks good nothing that i can see cut, does that wire go to the trunk? will i be able to see it? i will check the harness in the rear too..
I thought you had an El Camino. If you have a trunk the connector is close to the side light on the left side. If you have a El Camino this is this is the wiring diagram.
No im sorry, i should of told u i have a 78 malibu know, sold the el camino last yr 😢 ....i did see a connector to the left side if im standing in front of the trunk, but havent looked closer...i will when i get home...but the brown wire is located there right?
That's where the brown wire is. Try a test light on it to see if the power is getting to the back. Sometimes the connection is poor and needs to be cleaned. I assumed from your name you had an El Camino....
Ok so today i checked the brown wire from fuse box all the way to the rear trunk, it all looks good nothing cut, good connection , all tight and secure, my next thing to do was to check the fuse, lights up like a charm, so should i remove me tail light and test light the connections where the bulbs go on the turn of the key? Or just turn on my head light and test? I need to get this fix or i can drive it at night since the tailights dont turn when lights are on 😢
Here the diagram i used for the fuse:
I'd turn the lites on, check to make sure there is power to the brown wire at the connector on the fuse box and if that's good do then I'd check the connector in the trunk. If you have power at the connector in and out then the problem is between that connector and the lites. All the lites at the rear are grounded by the same wire so if the brake lites are working then you don't have to be concerned about the ground
Ahhh ok i see, i will do so when i get home...know what if theres no power to the brown wire from the connector from fuse box??
What i think it probley is, when i washed the malibu, i think water gets inbetween the tail lights and maybe go to my wires, all the connectors have been changes, cuase there was alot of corrotion when i first got it, i went to junk yard and grabbed like 6 and changed them all....i will have to remove the tail lights and ck there too....but i will keep u posted. :mrgreen:
aluminium wire is bad for corrosion, you can't splice into it and it can break if you bend it too much. I'm changing that harness this winter and making my own with copper wire. That diagram you have for the fuse box is a nice one. Thanks
Ponticgp:
You were correct!! The dayum brown wire that goes to the trunk was loose, so i guess factory had it sliced in with the trunk light, and it wasent even connected, well it was, but not tight, it fell apart when i touched it, so i took out the wite from the trunk light and ran brown to brown and its all working correctly, and for some reason my interior lights come on know??? Lmao :rofl:
Thanks pontiacgp::your the best!! Know i can drive at night..
Here is where it was loose from:
Lights on:: HURAYYYYYYY!!!
