1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
87 ss tail lights not working
Discussion in 'Electrical and Interior' started by viera, Oct 30, 2012.
Thread Status:
  1. viera
    viera Greasemonkey
    Jan 29, 2011
    169
    I already checked bulbs n head light switch (both r new). Everything else works except my tail lights. Brake light works too. What could it be??
  2. pontiacgp
    pontiacgp Rocket Powered Basset Hound
    Mar 31, 2006
    19,937
    2,119
    Kitchener, Ontario
    there is a brown wire on the left hand side of the fuse box. I think it's the 3rd or 4th wire up from the bottom. That is the wire that feeds your back lites, it's an aluminium wire and probably the source of your problem
  3. Rasheerh
    Rasheerh Master Mechanic
    Nov 15, 2007
    388
    9
    Cincinnati, oh
    this happened in my cutty, my wire was broke bought a connector for wires and fixed the problem
  4. wonderboy24
    wonderboy24 Royal Smart Person
    Jul 10, 2012
    1,043
    291
    83
    Davenport, Iowa
    get a test lite and start chasing wires.
  5. viera
    viera Greasemonkey
    Jan 29, 2011
    169
    Sure enough... Wire was cut when alarm was install I guess. Thanks a bunch man!!
  6. lg1200
    lg1200 Master Mechanic
    Mar 1, 2011
    308
    2
    pontiacgp..i hope you're around in a few weeks when i drop this motor in and i get to my wiring.. :mrgreen:
  7. 80ELCAMINOFLAKE
    80ELCAMINOFLAKE Comic Book Super Hero
    Sep 2, 2010
    2,742
    11
    38
    California So Cal
    I have the same problem, just happened, my brake lights work when i step on brake, but when i turn my lights on, my side markers and front lights turn on, but my tail lights and license plate light wont come on.. I checked the fuse and it was blown #20 fuse, so i changed it and tried it again, and nothing .. All the other light come on...
    Pontiac: could it be that brown wire as well.. I will ck light bulbs, but if i step on Brake that means the bulbs are not it?? Right?
  8. pontiacgp
    Mar 31, 2006
    19,937
    2,119
    Kitchener, Ontario
    if the brake lites work and your parking lites up front but not your tail lites then it's more than likely that brown wire. It's aluminium wire and it causes problems
  9. pontiacgp
    Mar 31, 2006
    19,937
    2,119
    Kitchener, Ontario
    Mine had the same problem so that's how I knew. It took me a while to figure it out tho when it happenned. Glad I could help you out
  10. 80ELCAMINOFLAKE
    Sep 2, 2010
    2,742
    11
    38
    California So Cal
    Ok sweet! i do see the brown wire going to the back like in a tube to the fuse box then back to the trunk...i will follow it to make sure it all good...thanks
Loading...
Thread Status:
Share This Page
