One thing I have done in the past to help with belt slipping on a v-belt system is sand blast the inner part of the pulley where the belt rides to give it a slight texture to grip onto.
Yup this is my 3rd time adjusting these belts lolOlds V8''s can be a nightmare due to missing spacers, 4 different water pump lengths and pulleys only working with the correct length water pump, unless you get creative.
I had to tighten the ps belt and the ac belt as well. Just glad I got rid of that damn squealYes sir they cam be a pain in th a$* that's for sure....mainly misalignment I had the same problem when I got my 86 missing bolts and spacers just got creative.
No ac on mine...but that belt noise can get real annoingI had to tighten the ps belt and the ac belt as well. Just glad I got rid of that damn squeal
With no a.c. there's to much pull on one side. You and lighten it up with a dual groove p.s. pully. Dorman pt # 300-125. My a.c. has been removed since the engine rebuild and no squeal.No ac on mine...but that belt noise can get real annoing
No squeal with single pulley it's just when I got car were missing a lot of spacers and what not so I had to improvise. But thanks for the info...as a mattee of fact I did try the double pulley and it had a hairline fracture and was no good...just think its not made like they were.With no a.c. there's to much pull on one side. You and lighten it up with a dual groove p.s. pully. Dorman pt # 300-125. My a.c. has been removed since the engine rebuild and no squeal.
Definitely and embarrassing if it’s in public lolNo ac on mine...but that belt noise can get real annoing
