Nope, not normal, but there is what is called lean burn mode that it will go into when light throttle, OD, and lockup to maximize fuel economy. Believe it or not, your 91 octane can even cause this. These were the last tables we dicked around with getting my big block to run on the triple C. Of course, it needs premium but we got it to work. It seems counter intuitive but try 87 gas and, as someone else mentioned, if your egr or even your gas fume canister valve are sticking, can also cause it. Just a few ideas for you.
