Are hands down, the WORST mechanically constructed cars i've ever worked on. It's not rocket science why pontiac went out of business, or why they are at fault for people losing faith in "American made" cars.
I've replaced, literally, EVERY SINGLE ****ING LINE ON THAT PIECE OF sh*t!
Yeah this is a rant.
First the fuel line ruptured, in 3 places. Had to replace 4+ feet with rubber fuel injection hose because replacing the entire line is a feat of engineering, mostly because the line runs through the ****ing frame.
Then, i set out to fix the brake leak in the rear line, go figure it leaks almost in the same spot where one of the leaks in the fuel line was. Well that took forever because the line kept falling apart, finally got it, just to find out the FRONT BREAK LINE IS ****ING LEAKING TOO!!!! and it has an extra layer of shielding which only serves one purpose, acts as a ramp for the leaking fluid so you can't just replace one part of the line, you have to replace the entire ****ing thing.
Gets even better, thank god the front driver wheel doesn't need bleed, cause the bleed is stripped, and rounded off. And the master cylinder is bad, because the back brakes won't even ****ing bleed.
Like billy maze said, BUT WAIT THERES MORE! Power steering leaks at an alarming, awesome rate. Right where the line goes into the rack, it leaks at that fitting. . So i used a piece of rubber hose, JBweld and two high pressure clamps to slow the leak for now, until i feel like pulling the wheel back off to **** with it again.
But thats not all this package deal includes! Theres a vibration coming from the right front wheel at 50-55 MPH, goes away under or after that though, so i'm assuming its the tire because the rest of the suspension setup looks fine, tierods are ok too.
Also the car blew a head gasket awhile back, and my dad fixed it, the motor seems to run pretty good, minor valve tap when you first fire it up.
Guess how many miles this car has?? under 80 thousand.
I think whoever was put in charge of the design of this car, needs to be court ordered to drive a 96 grand am for the rest of his life.
