Hey..
I got a Taurus last week and two codes came up, P0401 & P0430.
P0401 was a bad DPFE Sensor which I replaced and the code is gone now.
P0430 - I am 90% sure it is the catalytic converter.
I am yet to get the new catalytic converter as I need a little more money but also I wanted to be 100% sure before I get it. So I spent some time trying to figure out why assuming the converter is done went bad. I replaced the plugs & wires and looking at the plugs, I suspected a bit of a lean condition. I then checked the fuel pressure at the fuel rail and it was good but I went ahead and replaced the fuel filter anyway. Next I tested the MAF sensor and it was good.
Then I checked the vacuum pressure.
- The pressure held steady at the correct reading at 18
- When I held the RPMs higher, the needle started to drop initally but then went straight to 20 and stayed there as I held the RPMs steady
This is not supposed to happen when I add RPMs doing a vacuum pressure check, correct?
Then I hooked the scanner up to check fuel trims.
STFT all checked out good
LTFT was where I saw the problem
LTFT
Idle = Averaging +3
1500 RPM = +8
2500 RPM = +11 to +15
So at higher RPMs, the car runs lean.
Does anyone know what the next step would be in diagnosing this?
This is one reason why I don't want to replace the catalytic converter immediately, I read that if the car is running lean, then the catalytic converter would perform inefficiently. So I figured that maybe I should fix the lean condition and then check the converter again so I wouldn't be wasting money.
3.0 OHV
Thanks in advance
LTFT
Idle = Averaging +3
1500 RPM = +8
3.0 OHV
Thanks in advance
