A/C and heater problem
mike reese
22
So my A/C and heat does not work on my 1984 monte carlo ss. what should i buy and how do i fix this issue?
Zacheus
15
4
It could be a lot of things .. a little more information about the specific symptoms would help
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
turn the fan on disconnect the plug on it get a test light and see if there is power going to the fan.
If yes u need a new fan motor. If no start with checking the fuse.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Test light
there will be a plug on the brass tab take it off put the alligator clip on the test light to the ground on the battery the put the pointy end into the plug.
make sure you turn the fan on.
