A little advice please....
Tony1968
2,324
5,136
NW Indiana
Removing hvac then brake booster, etc. Want to clean up firewall and hit it with some satin black.... Should I just wire wheel firewall or DA with some 80 grit? Just want it to look clean when done. Thanks in advance.....
Rktpwrd
Builder of Cool Shjt
4,180
23,985
Calgary, Alberta, Canada
It all depends on how nice/carried away and into it you wanna get Tony. I see quite a bit of factory undercoating on the firewall, do you want to get rid of that, or just repaint over it?
It’s very easy to disappear down the rabbit hole with these types of things, just look at Olds Cool. It started out as a simple rust repair and repaint. More info is gonna be needed for us to adequately answer your question. When I had the engine pulled from Olds Cool, I just did a simple clean, scuff, mask and spray bomb job, but The Juggernaut got holes welded up, seams smoothed, and the full custom treatment.
Let us know what you’re looking to do.
Reactions: 4 users
Dayzedandkonfuzed
971
1,268
Anglemont, BC
I once stared down the barrel of smoothing the firewall completely in a 79 firebird. Ended up just smoothing all the dimples and small wrinkles. I used a wire wheel on an angle grinder to take all the paint off, scuffed real good with a scotchbrite, and sprayed etch primer then high build after filling the dimples. Sanded that down and sprayed it semi-gloss black, looked pretty good. A total smooth look is a TON of work, and no base model 79 mullet is worth that.
Tony1968
2,324
5,136
NW Indiana
I don't want to smooth it up like totally custom or weld anything. I have a delete plate for hvac removal.
Maybe I can pound some stuff down as it can be a learning experience? Before I get to real bodywork?
ck80
Moderator
Moderator
5,743
9,123
Well, undercoating you'd want to scrape off with a putty knife as best as you can before starting much surface prep.
I'd recommend getting a decent wood handle one, and apply gentle heat to the knife blade from a low temp hand held torch just long enough to heat the blade a bit (don't cherry red it) then scrape. Think the $15 blue bottle type from walmart or home depot. It will help cut through and loosen it up. Resist the temptation to torch the undercoating as 1) you don't want to start a fire, 2) you don't want to heat the metal and warp it.
If you don't remove the undercoating first it'll foul up whatever you use prep the surface.
Once I moved south I'd just stick something in the sun in the summer, let the heat do my softening for me.
After that it's your perogative, but I'd just scuff lightly anywhere that was factory paint. Really only get into the spots where paint is gone and surface rust took over.
Tony1968
2,324
5,136
NW Indiana
I will do that. I have small propane torches all the way up to B tank acetylene so I'm covered. You saved me some time already. Thanks
mikester
2,930
3,730
Small town NY
You dont need heat. You dont know whats on the other side of the areas youre heating up. Not good. I scraped most of the undercoat off and kept washing everything down with cheap lacquer thinner. Then I hit it with sandpaper. Its just work and a good amount of time. It looks like all the screws are out of the AC box. Thats easy too. Wax and grease remover, cheap thinner and a ton of time. You can get the new seal kit or just the box to firewall seal from Mikes Montes. A little bit of low gloss black and they can look pretty nice.
As far as the frame I used a Dewalt heavy cup wire wheel and a 4" grinder. Again, it takes a lot of time to get the rust and crap off. I did the firewall in body color on my wagon because the motor is black. I like contrast under the hood. But thats just me. Everyone has their own tastes.
Reactions: 5 users
oldsofb
1,387
4,020
Maryland
Been there! Am there!
Eastwood makes an undercoat cleaner that works very well (and smells like oranges). Keep us updated.
Hutch
Reactions: 4 users
shoedoos
406
403
I think we have all missed something else in the OP's pic.....look at that dash.....yes, not a crack in it.....congratulations and use kid gloves if you ever remove it....
