The dual snorkel air cleaner is the most valuable part. The pulley set up, if on there is better than the Vin Y cars. The carb would be next in value.
No. I meant WITH the air cleaner and everything it would be 600-650 starting price. The air cleaner alone is an easy 150 or so if in excellent shape. 500 starting without the air cleaner. The ECM Prom, carb, cam, and air cleaner is the only thing that really made a difference on the 84 HO engine over the standard LV2. It’s still an LV2 but a little different. If it’s a mid-January or later car, it has the dual belts on the power steering pump. That’s a better setup IMO.Pretty sad when an air cleaner is worth as much as a whole engine!
