So what happens when the Cold AC is on,will it still flow air from the outside?Yes if the car is moving you will feel airflow from the floor vents
Once the ac is turned on max the vacuum manifold closes off the fresh air from outside and recirculates the cabin air. If you move it off max it will combine the two.So what happens when the Cold AC is on,will it still flow air from the outside?
thank you Anthony...Once the ac is turned on max the vacuum manifold closes off the fresh air from outside and recirculates the cabin air. If you move it off max it will combine the two.
