AC brackets froze?
Landon Collins
10
23
Rogersville
Been trying to put a new water pump on my 82 Malibu wagon(305, AC/ powersteering), but I cannot get the AC Compressor to budge on its adjustment rails to remove the belt. Im unsure if the power steering pump below it needs to move first but its very hard to tell as there doesnt feel to be any give in the compressor. I have both locking bolts unscrewed and checked that the bracket faces havent simply rusted to the compressor itself. Im pondering if the power steering pump needs to be loosened first in order to let it swing up, and thus let the compressor swing down a bit to make enough room.
Am I missing something here folks? IM working in the dark almost literally so perhaps Ive overlooked a bolt I need to wrench loose first.
Ribbedroof
4,930
7,073
Wellston, OK
Loosen the pivot bolt?
A6 or R4 compressor? Original would have been R4
19,996
Try a bigger wrench!!
  • Useful
19,996
R12???? 4 bolts on the top and off
I should say 4 on the front 4 on the back....
U have a serpentine system??
Landon Collins
10
23
Rogersville
It’s an NOS R12 compressor, but the system has 134a fittings on it so I assume it’s just had the heads swapped out on the fill/drain ports. I’ll have a look for these other bolts tonight.
Ribbedroof
4,930
7,073
Wellston, OK
R12 is a refrigerant
R4 is a rotary 4 cylinder compressor....the short one.
A6 is an axial 6 cylinder compressor.....the long one
12,179
9,804
It still doesn't describe what compressor you're using. Your year would have the shorter R4 rotary compressor. Earlier cars, like mine, would have the A6 axial type compressor. They both used R12 refrigerant originally.
I think Brian pretty much described both types.^^^
19,996
this
compressing-air-on-board-compressor-harrison-r4-compressor
or this
Ribbedroof
4,930
7,073
Wellston, OK
Compressor usage was dependent on year AND engine, both types were used in the same years.
But, for a factory installed 305 in 1982, it would have been an R4
