What is the speed of the ac compressor supposed to be in relation to crankshaft speed is it 1:1 or should the ac spin faster than that?
My crankshaft pulley right now is 7" and if I go with a new R4 that has a 5" pulley but the add on pulley if it works would 5.5".Most that l've seen the crank pulley is the same size as the balancer so say 8" but the compressor is only a 6", so with that l would say the compressor runs faster. So l guess the ratio would be 1:1.25.
I would install an RPM switch to kill it at a relatively low speed since I shift at 7400+Either way it seems comparable. I think the only thing that really matters is if your going to be pulling crazy rpm's.
