Lots of opinions on this. What do you add to a battery that is low on acid/water? Last year I bought a brand new deep cycle battery from Sears and it must have been sitting on the shelf for a LONG time. Each cell was down several inches. Not knowing if it just evaporated or was not filled properly I added battery acid to the cells. The battery charged up and worked great all season in my Whaler. After sitting down my basement all winter it needed some more but of course now I knew the water had evaporated for sure. Still, it was not much so I again used the battery acid to top it off. I just checked it after sitting out on the water all summer and it was way down again. Now normally I just add distilled water but after doing that it takes a long time to charge up the battery. Worse, after doing that for years the battery will not take a charge properly. I am assuming that the acid is also leaving along with the water vapor and eventually you are diluting the acid too much by adding just water. So this time I made a mix of 25% acid and 75% water. I added that to the cells and charged it. It was charged 100% right away. That seems to be the ticket. I am curious because my cars sit for a long time and also lose water. This would seem to be better in the long run. Any chemists out there know what is best?
