Restomod sponsored the 2016 PT and I talked to them a lot about a dual EVAP system for a wagon or suburban and they said no problem. They completed a install on 68 Cutlass with the Bluetooth controls. I was impressed and will consider them on my next build.
Also search on youtube. There are at least 3 guys that have done it there, although the process is not well documented. If you are willing to reach out to some of the "urban" aftermarket shops that work on old school cars, there are shops in Chicago and South Carolina that have done them 100 times, they might be of some assistance.
Your comment about the vacuum selector interests me. So is there enough parts out there now to put the stock controls back in working order? Is there schematics to show the routing of the hoses?
I'm sure an FSM would have the routing. There's only 2 vacuum lines to the engine compartment- 1 for main vacuum to the selector (purple) and 1 to the heater control valve (gray) on AC cars (heat only are cable actuated). The only thing the vacuum does is select the vents- heat to vent to defrost and recirc/fresh air for Max AC.
