Aftermarket Radio Wiring Help
Tynan918
1,136
249
35
I've installed an aftermarket radio, but doesn't shut off after I shut the car off, and even when I power it off, it drains the battery over night...
Anybody know how I should wire it to keep it from staying on after the car is shut off, and possibly save my EQ settings after the car is shut off ?
So only connect red to red, and tape off the orange/constant wires ?
No, both wires need to be hooked up. Your stereo will require constant power and keyed power. If you post the model number of your radio I can look up the wiring diagram to better assist you. Do you happen to have a multimeter so you can check your cars wiring? That will help us point you in the right direction of how to wire it up.
Reactions: Tynan918
On the radio harness it should be a yellow wire. The Red, black, and yellow/orange wires are usually together on one side of or on a separate harness. The speaker connections are usually on the opposite side.
