If you unplug the connector at the compressor and replace the fuse, can you turn on the a/c without blowing the fuse? I'm wondering if the clutch coil is shorting to ground.
If I unplug the connector at the compressor it still blows the fuse as soon as I switch the ac on. Tracing the green wire at the compressor this leads over to the accumulator pressure cycling switch. I checked the continuity of the green wire from the pressure cycling switch to the compressor and it checked out fine at 0 ohms. The only way I have found that it does not blow the fuse is if I disconnect the connector at the pressure cycling switch. I can then move the HVAC controls to any setting and the fuse does not blow. I did check the pressue cycling switch and it seemed ok with the rough test I did. It showed an open circuit with no pressure applied and 0 ohms with pressure applied. If its not too expensive we are going to try replacing that. Just throwing parts at it right now as not sure how to track down the issue so any other direction to track this down would be appreciated.
