Being my Cutlass is a diesel I have 2 batteries (2 Duralast GoId 1000CCA) relocated to the trunk. I upgraded to a CS144 alternator. I grabbed one out the junkyard out a GM Minivan. Changed the pulley to the V-belt style. I wired it wrong according the the Alternator shop, which is where I took the CS144 after it lasted one week. Altho all the websites says the Sense wire can be hot all the time. They said not too. And I believe them, because I didn't changed my wiring set-up after they fixed the CS144 and this time it lasted a month. Took it back to them. For some reason they keep their word on the warranty (Altho I was ready to pay). I changed the wiring to where the sense wire was hot only with the key on. 2 years later no problems.
On with the main topic. My Sound system was 2 10" Alpine Type Rs wired to 2 ohms. Using a 1800watts (Cant remember the brand, Im currently overseas so I havn't seen the car in a while) But the RMS was around 600watts per speaker. It was stupid loud. I downgraded to 1 10" and it is still too loud but now I have more room for other crap in the trunk. I loaded tested the Alternator once. With the System turned high, glow plugs on, Bright Headlights on, Heater on Max, Flashers On. I got the Alternator to pull around 110 amps.
On the street I never had any problem with dimming headlights or nothing. Highly recommended
Edit: After going to my Cardomain profile to look up what amp I have, it is a Visionik 1800 watt Amp wire down to 2 ohms about 500 watts per speaker. I guessamate 500watt, being they overrate the amps from the factory (being a cheaper brand). So I think 500 watts is fair. Eitherway its too most bass for me. I guess, Im going old. I was kewl for about the first month.
